Syntetic or high performance fluid
TampaDriver
Car: Cars
just changed transy fluid and put in high performance oil but now it does not shift smoothly. I shifted better before changing oil. What do you think it is?
Daunttless
Maybe you did it wrong?
redrocket
Car: 1987 Nissan 200SX SE
2007 Chevy Silverado Classic Crew Cab
1999 Kawasaki ZX9R
wrong weight oil
TampaDriver
Car: Cars
I put 80 W - 90 while it requires 75 W - 90 ... I don't think that could cause that much of a dfference...
Aries
Car: LT1 240SS
You may have put in too much fluid.This would cause a little bit of slipping as it shifts.
I did this not too long ago as well.Just let it run for about 10 minutes, and check the level with the dipstick.If it is higher than the top of the HOT marker then drain a little out and repeat.Ideally you want it in the top 3/4 of the HOT mark after idling.This way when you really get on it, the overflow valve on the transmission isn't triggered by the rising level of the fluid.
