syncros
eastcoastchaos
Car: 95 240sx
my third gear syncro is a little screwed and i'd like to know how to fix it. if i do a lot of rev matching i can shift it smooth all day but since i have the stock flywheel it takes far too long before i can slap it in gear. and at this point i don't even need the clutch. it just takes too long and too much work. if i regularly shift third there is a little grindage then it pops right in. so how can i fix the grinding. can i get just a new syncro put in or should i consider a whole new transmission. and if you have any idea how expensive.
i searched but didn't find what i was lookin for, sorry if this has been gone over allready. thanks~ben
BadMojo
Car: 2007 Mazdaspeed 3
eastcoastchaos wrote:can i get just a new syncro put in or should i consider a whole new transmission. and if you have any idea how expensive.
You *could* get the transmission rebuilt, but it's gonna cost a lot. Can't give you exact #'s, but I can guarantee it's going to be more than a low mileage used transmission.
You might want to try changing your transmission fluid and see if that helps. Some folks around here swear by Redline products.
eastcoastchaos
Car: 95 240sx
sweet deal, i'm doin the transmission fluid tomorrow so i'll see if that helps
zion
Car: cars, guns, the usual
Just a quick question to any of the tech guys out there. Is is possible to convert a 5 speed trany to a 6 speed if you take it somwhere? Just out of curiosity...
180fan
Car: 89 fastback
You can buy the gear kit. Those are generally $6k+ from what I've seen from Greddy, OS Giken, HKS, etc. Very expensive to upgrade to a 6spd from a 5spd. Then you can take it to a transmission shop to have them install the new stuff.
Fenvy
Car: 2005 350Z Base 6MT
where do you get redline stuff?my local autozone or kragen doesn't have that
knowleqe
loveless, go to superior nissan or superautobacs. o yea, what street do you live on?
Fenvy
I live across the street from nogales high school.
where is superior nissan and superautobacs? haven't heard that around our area.
Doogz
Car: '89 240sx coupe
Replacing the synchros is really a simple task. I need to do it myself but i was waiting until i had a reason to drop the transmission (i.e. clutch or flywheel install). As long as the gears themselves aren't chipped or anything then, yes, all you would have to do is replace the synchros. What wears out is generally the little teeth on the inside of the synchro that bite down on the hub. They should be sharp and pronounced but if you pulled them they would probably all be worn down.
Basically when you pull the transmission apart, its just a bunch of gears on a few shafts with some synchros and thrust washers here and there. Remember where everything goes and the job is a piece of cake.
knowleqe
Loveless wrote:I live across the street from nogales high school.
you live in rowland yet have never heard of superior nissan? :bsface . btw, SAB is in stanton
navysnail
you can get redline at myoilshop.com
knowleqe
search for the discount code here on nico for myoilshop.com too
BadMojo
knowleqe wrote:search for the discount code here on nico for myoilshop.com too
Even if you don't go with something pricey like Redline, some fresh fluid might do some good. Search around here on NICO, there've been some good discussions about the various choices.
It would suck to drop a ton of money on transmission fluid and still have the thing shift like ****.
BTW, make sure whatever you buy is safe to use with our synchros.
http://www.redlineoil.com/products.htm
You'll note that the Redline MT-90 and MTL specifically mention low corrosivity.
eastcoastchaos
Car: 95 240sx
allright the new syncro sounds like the best plan. how much should i expect to pay for a job like this and where should i go
eastcoastchaos
Car: 95 240sx
how much would it cost to rebuild the transmission or possibly even get a used transmission. thanks
