Al the gears in a transmission stay meshed. Wear will not cause a transmission to pop out of gear. And I'fd have a hard time seeing the dogs wear out to the point they would ever fall out. It would just simply have a hard time engaging the gear at all. But they are rather robust and would be difficult to wear down under reasonably normal use(not grinding the dogs trying to get into each gear all the time). I believe each gear has a detent-like mechanism to hold the car in gear. This may be worn out.hachibroku wrote:When the gears start wearing down it wont stay in gear. not the right answer but it could be that.
