syncro
Beep Beep, I'm A Jeep
Car: 240sx S13
I accidentally put G-5 gear oil in my trans and it was grinding and throwing the syncros off, so i replaced it with Royal Purple and its better, not 100%, but better that it was before. My question is, what else should i do to it, i know what im doing with engines, but i know little about transmission. Do i just have to give it some time? I doubt it will magically go away instantly once i put the new oil in.
480sx
Car: 1996 Pearl White 240sx
Nah you did damage to your syncros, you can drive it till it stops shifting or do some transmission work. Nothings gona fix it besides overhauling the transmission.
However its hard to say how much damage you did, you could be fine for a while but its impossible to say.
Car: 240sx S13
So it would be a good idea to start saving for a replacement trans/pay a shop to do it right about now
480sx
Yep. You can buy a replacement for much cheaper than you can get a rebuild done.
MTC
Car: 1990 Nissan 240sx "Pig Nose"
I rebuilt my trans and its not hard at all just take alot of pictures and take your time. There is a place in Portland Oregon called Alltrans and they have any new or used part that you could need! I got my syncro and full bearing kit for $150.00 Plus shipping. Not bad!
Car: 240sx S13
well, i replaced the oil, and the trans is working better, but now the car overheats. I wasn't before, now it is. Could this be caused by something like not enough gear oil (i put in almost 3 quarts, but not the entire last one) because i have done nothing between now and putting the oil in, or is it just a coincidence that i might need to replace my thermo and maybe water pump
and it only over heats when im maintaining speed, like on the highway or something, it doesn't have a problem starting or stopping, or even at a stop light for a min or 2
