ace0073 »
https://forums.nicoclub.com/ace0073-u50339.html
Wed Sep 10, 2008 11:39 am
Ok, first off this may be more of a general KA question but since the car I am referring to is turbo....i am posting it here. I am actually asking for another member but thats besides the point. Question is: What are the symptoms of TPS voltage being off? The situation was created when we installed some ITB's on my boys turbo KA 510. When I tried to setup the TPS, I realized that since the throttle travel was drastically different (shorter) there was no way to get the voltage correct. If i set it correct at closed throttle then it was off at WOT and vice versa. I ended up setting it at closed throttle which I am not sure if that is best. Not sure if this is a NOOB question or not but, honestly, I dont know anything about how the computer uses the info from the TPS so I am asking. Any 'useful' information will be appreciated. thank you
also, considering the voltage can be set at WOT or idle, if it is going to be incorrect, which one is best to set at?
