eazye2000 wrote:Well, you can run 20* of timing until like 5-6psi with 92-93 octane I do believe. I've not done it in some time though. It does sound like you got some cracked ringlands. They typically don't do much at idle, or even light throttle. They usually only act up when you boost and blast air and fuel into your crank case. Thus the smoke and such.The whole underside of my car is covered in 10w-30 Mobil, I've been there...I'm not familiar with your build. You still on a stock motor? If not, you should be able to get away with some detonation here and there as long as it's not prolonged. Stock pistons with not be so forgiving. One good detonation and they are toast.
One quick question. Do you have a wideband? Is the smoke being misunderstood as fuel? And what kind of turbo? My ball bearing garretts don't mind a 90* bend in the return line. Never had an issue. I use a restrictor though.
I've not thought this out totally. Let me ponder on this for a few.
Problem is I ran 15 psi once while setting the mbc. It was for like 2 seconds and at pretty low rpm, but on the dyno it spiked to 13 psi and my injector duty cycle went to 100%. It definitely detonated up top for a few seconds.
Engine is totally stock, only thing I've done is taken off the valve cover. I do have a wideband, the smoke is definitely not fuel. If anything it shows that I'm running a bit lean, but it's because of a torn downpipe gasket pre-sensor. When I had my exhaust all fixed normally my afr's were perfect.
Turbos is a t28 from a Pulsar GTi-R. It's basically a non ball bearing version of an s15 t28. The return line is downhill all the way, it's just not straight down. I had to go around my engine mount.
I got rom editor and nemysys running on my laptop earlier, I'll go over to my car tomorrow and grab the .bin for you to take a look at, if you want to. In the mean time, mind if I email you my data logs?
I guess more importantly, can I limp it home? It's about a 200 mile drive, I can stay out of boost. I've sourced a freshly honed block and new oem pistons for cheap, but I'll look around for some cp pistons, and if funds permit I'll look for rods as well. I'll check my oil level tomorrow, but I burned a whole lot more oil with my previous turbo so I'm not too worried about oil consumption. If fuel is leaking into the block past the rings, however, then I'll be worried.
Either way I'm not going to jump to conclusions until I do a compression test. I still might grab that block and other stuff I found on craigslist, just to have a spare engine to be building.
