Pushaq45infinit wrote:I'm new to posting in this forum but I've owned a 1992 q45 for the past 11 years. I recently had all of the fuel injectors replaced and when I picked it up I was told that the (the shop) were getting a code for the camshaft position sensor.....
Welcome to NICO. Crank angle sensors (CAS) do go bad but its pretty rare. Time to save yourself a lot of $$ and do a little DIY work rather than let your shop have you throw $$ at parts. It's easy to pull engine codes on the Q. The ECU is mounted behind the passenger side footwell. If you've never pulled codes yourself then Q45.org is an excellent, condensed source of information. The link for pulling codes is below. Come back and ask questions if you need to. Lots of us have done it "manually" and can get you a quick reply.
The CAS and MAF are two of the most important engine components and neither has a connector that is watertight. If you've had a radiator leak or live in an area with lots of wet and ice you can bet there will be some level of corrosion on these two connectors. The same style connector is on the injector harness so hopefully your shop cleaned up all these connectors when they had the intake off. While you're at it check the throttle position sensor and EGR solenoid connectors. All these connectors need to be corrosion-free (spray cleaner/toothbrush), lubed with dielectric grease, and the female pins tightened so the connector fits securely. Any of the conditions I've mentioned could throw a code.
Another thing all these connectors have in common is a metal clip holding the connector in place. If it wasn't installed properly or the clip is missing then the connector could come loose and kill the engine.
infiniti-ecu-codes-and-how-to-check-them-t60332.html
