Symptoms of bad subframe bushings?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Ive had a few people ask me about this and thought id make a thread about it. What are some of the symptoms of bad subframe bushings?
Brad-Man
Car: '94 Q45a w/Texasoil Accumulators
Silicone snot in front of and inside the track of the rear wheels - as me how I know....
TBrack
Car: none
Brad-Man wrote:Silicone snot in front of and inside the track of the rear wheels - as me how I know....
...dammit there goes more money I don't have
elwesso
2007 BMW M Coupe
Brad did you have any other symptoms? Im mainly talking about "feel" things.
EQwhipD
Car: 1994 Q45 (Totalled)/ 1994 Q45a (SOLD) / 1990 Z32TT
I dont know if it is asubframe bushing or not but I will explain my symptoms:1. Back right wheel drops 2X as fast as the left after going over speedbump2. car fishtails after going over potholes or other irregularities in the road
The strut seems to be find after I did the push down on the back of the car test. It also wears that back right tire faster than the other tires? Any suggestions. Wes suggested that it could be the subfame bushing or a bad spring?
-Evan (NC)
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
Am I to presume you have already checked alignment and other rubber bushings? Sub-frame bushing failure is not difficult to SEE. Its easy to remove the short stamped metal braces on the front ones.
elwesso
2007 BMW M Coupe
im just trying to get symptoms of what owners experienced with bad subframe bushings. Mine are fine, but if someone posted up on here and asked about a certain symptom, id like to be able to know what symptoms subframe bushings give without actually checking them.
