dareo »
https://forums.nicoclub.com/dareo-u8796.html
Mon Feb 24, 2003 11:36 am
Remove valve cover, look closely at the chain. If the chain's links are close together and the chain appears to be running straight its probably OK. I guess a better way to put that is: Imagine if you had the whole chain out, in your hands. Could you twist the chain a lot? If you held this chain straight out, how much would it curve? Mine was sloppin' all over the place.
Next look for the tensioner and the guide. If you cant find the guide, (originally plastic and it will vanish after enough mileage/abuse) then you probably need a timingchain job done. Shoot yourself in the head because it will be less painfull than the timingchain job. Its actually not that bad, but if you got the money PAY SOMEONE TO DO IT. If your car is anything like my red one were working on now, PAY SOMEONE! Odds are a lot of the bolts haven't ever been off in 14 years.
If you've got good tools, time, and you think you have some mechanical skills, by all means give it a shot. By the time your done you'll know why mechanics quote so much to do it.
Price of the timing kit, about 100 bucks. Oil, coolant, gaskets, little crap you might as well replace while your there like the Thermostat, can add you up closer to 200 bucks parts alone.
