brokeAs240sx wrote:If it's dry & your fluids are good, should be fine. When they go bad, they leak - that should be the most typical way racks go bad.
Here's one thing to check (happened to me): tire pressures. The steering in the Sentra was REALLY bad - I thought it was the 17" rims w/ 235's I just installed - found out later during autox, I was way underinflated.
Yeah I thought that too.I check my tire pressures semi-religiously (about 3-4 times a month depending if the outside temps are really fluctuating). I run about 34-35psi all around for daily driving.
Do you watch my posts Brokeas? Or do you work for FRsport? BTW, thanks again for your recommendations a while back.. I'm luvin' my Buddy Club seat... best part... no one else who wants to drive my car can fit in it! HA!
