chezina »
https://forums.nicoclub.com/chezina-u810.html
Sun Feb 23, 2003 5:12 pm
The DET switches into the low maps that's right, the fuel cut is only related to the MAF signal (as far as i know) and the low fuel map is richer in general(to be on the safe side), and in the low ignition map the timing is also retardet(to be on the safe side), i would assume from this that the ECU trys to optimise a DET signal with giving more fuel/retard ignition to reduce knocking and this shoudn't hurt the boost cut.
