Nesquick wrote:personally, im stickin with my MAF sensors.
THE REASON: on map converted engines, its based off of a fuel curve that is programed into the ECU and it does not change.
so basically, your fuel map never changes. no matter what the air conditions are outside (dense, thin, wet, dry, etc).
but on MAF sensors, it calculates the density and adjusts the fuel map per according to the air conditions.
Most MAP based Engine managements use Air intake temp sensors to correct for these conditions. From the Haltech Manual:
"Inlet Air Temperature Sensor
The air temperature sensor is used to compensate for changes in air density due to air temperature. Cold
air has a higher density than warm air and therefore requires a greater volume of fuel to maintain the
same air/fuel ratio. This effect is most noticeable in forced induction engines. The Haltech ECU will
automatically compensate using the signal received from the air temperature sensor (once the air
temperature correction map is setup and enabled in the programming software)."
