switched IP cant get online (360)
PC, Game console and Online gaming discussion forum
Lroi
Car: 1990 240sx
hey a quick Q I just swithced to comcast cable internet after having verizon dsl....witch I never had a prob with but my modem went, and my contract was up at the same time, so I fiqured Id uprade...now I cant get on the pc when Im logged on xbox live and cant log on xbox when Im on the pc....and I have to reset the modem everytime I want to switch....Im thinking its my router...comcast doesnt see a problem on their side, Im guessing its on mine....
I have a linksys 5 port workgroup switch as my link...is that the problem?...
M.O.B
Car: 91 240sx w/R33 Rb25det SII
I used to have comcast and I had to do the same thing, I didnt have a switch though. They told me I had to reset it when switching from my mac to ps3. Maybe their modems only recognize one port at a time?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Yeah, for comcast you need a router instead of a switch if you want to use your PC and Xbox together.
The problem is how their service works. If it sees more than one device, only one will work. If you use a router you shouldn't have the problem.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
MinisterofDOOM wrote:Yeah, for comcast you need a router instead of a switch if you want to use your PC and Xbox together.
You can actually setup the computer as a router using Internet connection sharing. That is how I have mine setup right now. I'll post a step by step Tuesday.
Lroi
Car: 1990 240sx
yeah my dad brought me over a router to use...I guess the swytch was holding me back....Ill be looking for that setup when you post it...thanks!
Pr0jeCt
it can be done on a switch.. a hub even, But from what i gather you are saying you try to take the cat5 cable from your pc and plug it in your xbox and it doesnt work until you reset the modem? yes that how it works.
Lroi
Car: 1990 240sx
Pr0jeCt wrote:it can be done on a switch.. a hub even, But from what i gather you are saying you try to take the cat5 cable from your pc and plug it in your xbox and it doesnt work until you reset the modem? yes that how it works.
yes thats what was happening.....now the damn router stopped working...am I doing somthing wrong?
Pr0jeCt
with the router unplugged plug your internet connection into the WAN port on router.. plug your pc's and xbox or whatnot into the ports for LAN.
Unplug your reset your modem and plug the router in and wait for it all to synch upit should work from there
Lroi
Car: 1990 240sx
ok I got the router to work, I think my crappy cat 5 is the prob...but now when I hook up it Im gettin that limited or no connect msg...firewall maybe? can I adjust it?
Pr0jeCt
limited or no conenction on what.. the xbox or is that a windows based popup message you are getting?
post the brand of router you have and i can give you more info
Lroi
Car: 1990 240sx
windows...linksys 5-port workgroup switch
Pr0jeCt
ok that changes everything then..all my advice is router specific.. only way i have been successful on a switch is to have 2 network cards on my pc... the internet goes into one of them. then through windows i "share that connection" with the other network card.. which i have the switch plugged into..see what im sayin? only way i have got a switch to work like that
google ICS or internet connection shareing
Return to “Gaming”
