switch to solid lifter?
XTCshri2222
Car: 1978 Datsun 280z L28ET Powered
1991 S13 Ca18det coupe - sold
ok, i hear alot of people with CA's talk about lifter chatter, i rebuilt mine, and even had someone look over my lifters, but yet they still make a hole lot of noise.
Now, is it dangerous to the motor in anyway if there is excessive chatter from the lifters?
And is it worth upgrading to solid lifters? I have tomei cams, stock lifters, valves and springs. The cam is 256 8.5mm lift mild poncam.
I will be beating the hell out of this car in October, i'm hoping to run it in the redline time attack at VIR.
bentvalves
Car: 89 Silvia K's
XTCshri2222 wrote:ok, i hear alot of people with CA's talk about lifter chatter, i rebuilt mine, and even had someone look over my lifters, but yet they still make a hole lot of noise.
For that lift, solid lifters wont do anything for you. If your thinking of spending that money on solid lifters, also factor in a variety of shims to get desired clearances as well, then PROCAMS, then turbo to make use of those cams. Just buy new OE lifters for ca18de. I did and my valvetrain sounds sweet.
Greg
