madmonkey »
https://forums.nicoclub.com/madmonkey-u178337.html
Wed Dec 28, 2011 3:02 am
ok so checked it with nissan consult
removed error code drove it and no code
checked the function of solenoid and it seems to be working, may be an intermittent fault who knows
well we looked at the data and most things seem ok yet the timing seems more retarded on the right side bank than the left, without having another model to compare im not sure if this is normal
so i have used the factory nissan oil and maybe that will make a difference as thats the only thing i have done and didn't put the right viscosity of oil in,fingers crossed its that easy....
if not then we suspect the chain to have stretched and is causing these problems
will scope the sensors then compare them to make sure everything is ok
major pain as that takes ages
and then might have to change the timing chain which seems like a mission
bummer
will keep posting in case someone else has similar problems
