swirl control valve delete questions
JDmisaac
Car: s13 coupe
05 scion xb
so i've read the posts on here about deleting this but it didn't state these things
i've pulled all the secondary butterflies out and the rod out now i'm at a standstill about what to do with the holes that the rod ran through but i figured the outer hole where the rod inserted into the manifold would cause a vacuum leak and each side of each runner where the rod ran through would cause turbulence between the runners so do i need to jb weld each hole off or any other suggestion on this pics would be great but either way do fill me in.
thanks in advance
isaac
Evaprototype
Car: '90 NA 2+0 Z32
'01 Xterra Extreme Edition
Isaac, when I deleted the emissions on my 93, I left the rod in for the SCV. If you're planning on removing the rod, I'd suggest getting those through-holes welded up. Also, I wouldn't be too comfortable with JB weld being on the inside of my engine, I don't know about you. :) Go ahead and take it to a shop if you don't have a tig.
Chris
zachattack_5491
Car: Pignose S13 Redtop SR
I used JB weld on the outer hole. It works like a champ. I don't think the inner holes matter that much. Turbulence on the intake is good for mixing fuel and air.
JDmisaac
Car: s13 coupe
05 scion xb
thanks for the info guys
much appreciated.
