They are all related. Try this article, and it will help you understand. If you get GR+ Pro, hopping and swaying problem will go away.NICONick wrote:I thought my violent hopping and swaying would go away when I bought SPL's collars but to no avail. I pretty sure the hopping is caused by my rears being blown, but why am I swaying? Same reason? Help?
Coilovers are being purchased soon...hopefully... (Stance GR+)
I too had this problem and it was aleviated tremendously when I put on a set of subframe collars and my rear swaybar back on. Depending on the size of the bump I can still feel it shimmy to the side a little but I think that's due to my car needing an alignment. I have really bad camber and caster in the rear.tamdo714 wrote:i had this problem. just get some spl subframe spacers and you're good to go
Inspect old bushings before you do anything. Depends on condition, you might have to get bushings, not collars.tamdo714 wrote:i had this problem. just get some spl subframe spacers and you're good to go
Install coilovers and RUCAs first, and you should go from there.NICONick wrote:Anything?
I'm sorry. I misunderstood. Yeah, jack up the rear end and remove 4 bolts and large washers. You should be able to see the bushing and see if there's any crack or completely torn.NICONick wrote:Go coilovers over checking subframe bushings first?
