SwayBars & Strut bars affect drag launch
LT_Z
Im getting some body roll but im wondering how sway & strut bars affect a drag launch ?
yeswepromise
ummm they probably help somewhat. they really help with the side-to-side movement. you might want to look into Do Luck floor bars. they are supposed to work against the front to back movement.
Exar-Kun
Car: 2005 350Z
wlel, they siffen the suspension, so tkae that intoa ccound, and yeswepromise is right, I woudl check into floor bars if your dunning hard drag launches(as well as drag-specific dampers)
-chetedit: man, oh man, I need a typing class. decipher if possible :p
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
I had very noticeable results with my strut bar and a rear sway bar, with a strut bar you really feel a tighter steering, and the sway bar keeps my car as flat as a dime.
LT_Z
Exar i was thinking that the floor bars would hinder weight transfer, Im no familiar with dragging the SX yet, but im thinking it is kinda light and might have problems hooking. So i was thinking all the weight transfer i can get would be a good thing. Im trying to make this car an all around perfromer. (and still turn 10's) :)
Nismo_Freak
Car: 89 Nissan 240SX
No rear sway... front sway is nothing but weight and sorta a safety thing cause the car sorta wants to wander around w/o one.
Strut bars are just chassis reinforcement and I see no reason not to run them.
Exar-Kun
Car: 2005 350Z
floor bars wouldnt influence weight transfer, it would just reduce the floorpan flex under a load(IE drag launch), which would actually result in better weight transfer to the rear tires :)
chasis reinforcement is a good thing.-chet
LT_Z
ok, now how much are they ? and which sway & strut bars you recommend ?
yeswepromise
tower and stabilizer bars = cuscofloor bars = do luck and i think they run like 500 dollars
LT_Z
so cusco for sway bars & strut braces ?
Nismo_Freak
For an ideal drag launch you don't want a rear sway ...
Altiman94
Car: 1989 Nissan 240SX
^ true
