sdtouge wrote:if you knew how to initiate at all, you wouldnt have to buy a sway bbar so you dont get understeer.
WTF are you talking about? Different cars, different setups, different drivers. Just because you are the best drifter who ever lived and can slide any car like the best D1 pro no matter what doesn't mean you have a clue about what you are saying.
Swaybars and coilovers do very different things. I put in a set of Whiteline adjustable bars existence and wow they are an essential part of my LIFE and very existence. In a nut shell stiffer swaybars in the rear makes for more oversteer, stiffer in the front makes for more understeer. The key is to balance the effects of the front and rear for a neutral handling car. Fine tuning ( why I like adjustable ) will allow for differences in car setup, driver style and preference. Doing something like taking out the front bar all together will make the car slide more easily but you will loose high speed stability, speed of transition, and feel and response from the steering. If you don't have mega bux to spend on pricey sway bars simple things like swapping out the factory bushings in the rear for hard ( urethane or metal ) often will make a big enough difference that you can be happy with it for a while. It's an old autoxers technique. I personally balance as your goal. Having an oversteer prone setup is great for low speed drift practice and beginners first day, but after that too much oversteer will seriously hamper your learning curve.
