sway question help!
gumby
Car: '89 240sx sohc
my '90 se chassis is lacking a front swaybar. is the se bar the same as the xe. i can get a s13 silvia JDM replacement but i dont know if its as good. got outbid on the cusco. id rather not drop $250 on a set but i'd like an se equivalent or better.
:eek:
rico05
Car: 1992 RMS13 w/ CA18DET
Stock SE/Q's front sway is 25mm. JDM K's front sway is 27mm. Personally, I run a JDM K's (USDM HICAS bar is the same) 21mm rear bar and stock SE front bar. Oversteer is fun.
BuudWeizErr
yeah, a cusco front and stock rear would be horrible.
the other way around would be ok though.
just get one of another s13.
gumby
Car: '89 240sx sohc
theres no bushing kit with it whatdya recommend whiteline other?
thanks rico u the man
thanks chunk
