sway bars
GhostDriver
Car: 1991 Nissan 240SX RMS13
are they're any problems with fitting aftermarket sway bars with an RB s-chassis?
thanks for the time.
Joe
might get a little bit of rub on the front depending on how it was mounted, but its gonna depend on how big the bar is.
regardless its not that much, and nothing a few light taps with a hammer cant fix. or just ignore it.
240wootie
Car: 1989 rb20 coupe, 2002 WRX
i've heard that the progress front sway bar will clear the oil pan just fine, but i dont have mine yet, so i cant be 100% sure...
can any one confirm that?
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
the A31 cefiro rb20 front sway bar bolts right up to the s-chassis and will clear all rb oil pans including the rb26 oil pan with out the front of the pan chopped.
GhostDriver
thanks for the input guys. i'm looking to swap a 20 within the next couple of weeks but i'd still need the car to be competent around the corners.
it'll need to clear a 27mm ST bar btw.
skylinegrl13
Car: 1995 Nissan 240sx RB26DETT swap
what year s-chassis?
mello88
Car: s13
I've wondered this too cause I have the thick *** Whiteline sway bar(s) on my S13. I know the Syko intall kit uses some spacers to relocate the sway bar bracket... Anyone else running the Whiteline front sway bar on S13 with RB20 and R32 xmember + nismo (or stock) mounts?
Mello
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
I will find out this weekend.
