C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sun Jul 16, 2006 7:25 am
I wouldn't be so quick to go out and buy sway bars as a solution for this. It sounds like you're complaining of problems with suspension rebound being too underdamped. Basically of you hit a upward undulation on your outer wheels in a turn, the car moves up with the road then floats for a bit when it peaks then comes back down into load as you come off the undulation. With rebound damping being too light, it can cause the suspension on the outside wheels to get too light for too long and not only has a tendency to lower traction momentarily, but also take a relatively long time to load the suspension on the outside again allowing you to grip the road. What you need is to stiffen the rebound which would cause your car to want to follow the road back down faster after you hit the peak of the undulation. While you can not eliminate the effect an undulation has on your car completely, you can minimize it. If the outside wheels go into full load more quickly, it will allow you to grip the road sooner and reduce the over all suspension movement that might make the road feel lost.
That being said, simply increasing rebound damping has negative effects. The ride will be harsher and perhaps have less grip on rough surfaces. Too much rebound damping in relation to compression damping would also cause a jackdown effect over rough roads and could end up causing your suspension to bottom out. Suspensions are always compromising things. Before you start buying parts, study the roads and conditions you drive-in. Be aware of what your car is doing. Read some suspension books to get an idea of how to correct certain problems. Learn how the corrections will negatively impact your handling and comfort. Based on all these things together, decide what your best compromise is.
