Sway bars for s13 coupe
naed240sx
Car: .....
I was under the impression that base model, non hicas s13 coupes had no rear sway bars, but looked underneath today, and its got one. Any explanations? just curious. Its puny looking skinny thing, and i want to replace it and the front bar. I dont have any suspension mods yet besides f/r strut bars, and I want to go with sway bars next. I want the stiffest bars possible (i hate body roll), But i dont want to fork over 300 bucks a bar. Any suggestions with links? and do all of the bars come with endlinks and new bushings, the endlinks on my car look like i could cut em with wire clippers(exaggerating but you get the idea).
thanks to all!
navysnail
all 240's come with sway bars. stiffer sway bars take away from the suspention's ability to be independant if you understand what im saying.
whiteline and suspention techniques both make good bars, as do some other companies.
SPL has some excelent solid adjustable endlinks.
Axel Grungy
Car: 2001 G20 5spd
i beleeeive all s13s had front and rear, s14 is different story tho. pick up some suspension techniques sway bars, comes with all endlinks and everything you need. im happy with them, verrry little body roll
naed240sx
Car: .....
But by reducing the independence, body roll is greatly lessened, so cornering ability is improved, but ride comfort is decreased. So stiffer bars will only help handling . Right or wrong?
naed240sx
Car: .....
Whats the cheapest place to get both front and rear?
navysnail
i was just saying the thing about independancy to give you a little info. any of the companies i mentioned are fine, as are others such as cusco and such. for the parts, check out our sponsors on the right.
onosqv
Car: '92 240sx Vert
naed240sx wrote:But by reducing the independence, body roll is greatly lessened, so cornering ability is improved, but ride comfort is decreased. So stiffer bars will only help handling . Right or wrong?
yea, you either get handling or comfort... unless you want to spend a lot more money, hehe.
Yea, there is lil body roll. I just did s.t. sway bars + kts coilovers + some other goodies upgraded from kyb agx + sportlines -> it's sweet. stiff, but nice.
They are very comfy at 70+ mph
swwifty
If I were you, I'd spend some money on a good shock/spring setup. Either being complete coilovers, or buying some springs and good shocks. Personally, I don't like the way swaybars limit the supension travel. They also don't have an effect till the suspension is compressed to a certain amount on most cars. I'd eliminate body roll by increasing the spring rates, that will have a more drastic effect on the handling of the car, then a swaybar. Be sure to match your springs with good shocks. I prefer to just buy a coilover that has a shock and spring that are designed for each other.
naed240sx
Car: .....
I am planning on buying coilovers, pretty much decided on megan racing
Axel Grungy
Car: 2001 G20 5spd
i just ordered some ksports
swwifty
i'd get thoose first, then see if you want swaybars.
naed240sx
Car: .....
sounds like a plan. Buying one component at a time would be the best thing to do. thanks for the suggestion. Sometimes I get kind of carried away with ordering
Fenvy
Car: 2005 350Z Base 6MT
just buy the suspension technique
they are about 250$ for both front and rear, bushing, bracket... did I mention the bushings are polyurathane?
.... yeah! I like them.
gumby
Car: '89 240sx sohc
yeah ST is the way to go unless you wanna splurge on whiteline (better links)
anyway you need to stack 3 washers (not 2 i dont care what the instructions say) above the mounting bracket for the front bar and at least 2 under the link nuts in the rear bar to make the bushings fit.
