sway bar...
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
Lunatic1120
Car: G35 Coupe
so i heard if i wanted better handling for my g...i should order some sway bar..so im actually on my way on ordering the stillen sway bar...
so i wanna kno exactly what does the sway bar would do for my g. and if theres a better way of spending $300 for better handling???...please help..thank you.
TeflonG35
Car: 2003 G35 Sedan
You have an expensive car. Cheap solutions usually lead to expensive repairs. Stillen Sways bars are on sale and are well worth there sale price if handling is your goal.
ocho
Car: 2004 G35 sedan
Sway bars will help by keeping the car planted in fast corners but will not afect ride confort. If you add shocks and springs you might end up with a GO-CART and a stiffer ride.
Ocho
goneracin
Car: 2004 G35X Sedan 1990 Mustang conv.
I think it would benefit from a bigger rear bar, but keep in mind that the sway bars can only fine tune the rest of the suspension. What is the car doing that you're not happy with? What type of handling do you want-street, drag, track, high speed mountains, city pothole driving?
Lunatic1120
Car: G35 Coupe
well..what i really want...is to be able to take a corner without my cruse control to jump on..and without sliding..so i guess that would be my main focus...
gwoods
Car: 2013 Infiniti M37x
1999 Nissan Altima SE limited 5spd
1992 Miata (soon to be turbo)
1965 Cj-5 with 327 v8
2012 Toyota Sequoia Limited
wider tires?
Sway bars are cool but your going to give up some comfort for handling
goneracin
Sounds like you should save your money for coilovers. It'll give you better grip and a softer ride than the stock set up.
Jacko3
Lunatica1120:
I honestly feel the stock set up is sufficient, at least for a 2007 G-35 Coupe, except you wan to feel every pot hole on the road. I am not sure if the sway bar for the stock 03 - 04, or 05 - 06 is different or not from that of the 07.
I agree with G-Woods, wider tires and quality tires will be best. This will cost more than $300. Genoracin's recommendation of coil overs or Gwoods recommednations of wider tires will cost you between $700 - $1500 either way. Suspension work isn't cheap in many instances. Just my 2 cents.
goneracin
Something to think about....any extreme changes you make will come with a cost (besides money) extreme tires may suck in the rain, an awesome handling car in the hills may jar your head on potholes and speedbumps. Its damn near impossible to have a car that will do it all(all being relative).
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
