sway bar
Shift_Perfection
Car: Altima Coupe 2.5s 6MT
is the 3.5 sway bar thicker than the 2.5? I have the 2.5 and want a better sway bar and I was thinking of gettinga 3.5 if it's thicker..
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
I believe it's just the front stabilizer bar that is thicker. 24.2 mm for the 3.5SE. I'm not 100% sure on the rear. I'd personally wait for an aftermarket set that would be thicker than the OEM to begin with.
Shift_Perfection
I think you're right. I want better handling on the car. That would be the rear sway bar I'd have to change right?
Mr. Music
Car: 2008 Altima Coupe 2.5S CVT w/ Convenience Package
In the family: '02 S15 Spec R, '09 Rogue
Shift_Perfection wrote:I think you're right. I want better handling on the car. That would be the rear sway bar I'd have to change right?
Not necessarily. Aftermarket springs/shocks will give you better handling, your wheel/tire set up will have its effect; but replacing the OEM sway bar with a thicker/stiffer one will definitely tighten things up.
Shift_Perfection
Well I don't want to do springs without doing full coil overs. So I think I'll wait..
GreyZone
Car: AC 3.5 SE 6MT Dazling White
Shift_Perfection wrote:is the 3.5 sway bar thicker than the 2.5? I have the 2.5 and want a better sway bar and I was thinking of gettinga 3.5 if it's thicker..
call the dealer...see if the part numbers are differnt
Lowering springs / shocks / struts /bigger wheels / wider tires are going to do most of the job, much moreso than the sway bar
