IIRC, d!ck has r32 rear swaybar on his s13.d3vilskid wrote:i was wondering since alot of parts are interchangable between nissan. are the rear sway bar interchangable too?
Its big. 26mm. I've never actually checked, but I think its hollow. Same everything, just used the stock D-brackets from the skyline.d!ck wrote:^what's that like? size? hollow/solid? uses the same d-brackets and bushings?
I have stock s13 front & rear sway bars too...d!ck wrote:yeah, pretty sure s13 fits from what i have seen. i have a stock 15mm one if your s14 is base model. you can have it for a few bucks plus shipping.
15mm > no swaybar.
I have the tanabe bar on the front (in pic is laying on the ground). I like it, 30.4mm.RB20DETodd wrote:tanabe bars are nice and not to expensive
d3vilskid wrote:hey thats nice, i was searchin for a s14 se sway bar with no luck. So i'll see if the s13 fits.
I have an S13 convertible front and rear bars in my garage that I've been waiting to sell to a lucky NICOnaut.Darius wrote: I have an S14 SE rear bar in my garage that I've been waiting to sell to a lucky NICOnaut.
Just to be sure, does "pretty sure" imply that it DOES fit? If thats the case, 94_240sx, do you have the mounting (D) Brackets + rubber with it?d!ck wrote:yeah, pretty sure s13 fits from what i have seen. i have a stock 15mm one if your s14 is base model. you can have it for a few bucks plus shipping.
15mm > no swaybar.
