ghx407 wrote:That thread that you linked me to was awesome; lots of useful information. This is what I got from it, please correct me if I'm wrong:
To remedy understeer: A stiffer rear bar will "pick up" the inside rear wheel, thus transferring more weight/traction to the front tires while decreasing weight/traction in the rear of the car.
To remedy oversteer: A looser rear bar will allow the inside rear wheel to "sink" to the asphalt, keeping more weight/traction in the rear tires while decreasing weight/traction transferred to the front of the car.
Just to make sure I got things correctly, your car now tends to oversteer more than it did before right? I thought a lot of ST guys said that the ST bars made them more prone to understeer. Are you only running the rear ST bar with stock front bar, are those guys talking poop, or is my lame analysis wrong?
Yea , with my driving style , and with my setup , my rear sway bar definitly creates oversteer. Once i start the Auto X season this year , i will be removing it , and re-installing it for drift events.
Not sure what you mean by ST , Strut bar? They are'nt the same as sway bars.....
If your in Auto X / SCCA / NASA , You will want to experiment with running an aftermarket front sway bar , with no or a stock rear sway bar.
The front end of your car "rolls" more into a corner than the rear. If the rear is to stiff to compensate , it wont follow the front like it should. Thats why the rear will tend to lift or lose traction.
