sway bar, meet oil pan. oil pan, this is sway bar.
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
I am using the top-hat mounts, bought them by calling the number on their website. My rb20det's oil pan keeps rubbing the sway bar. So far it has only rubbed off a little paint. I thought everthing was supposed to clear when using the mounts? Is there any sway bar either aftermarket or from some other car that will work? I have a spare z32 sway bar, but it doesn't look like it will work.
If all else fails I can get one custom made I guess.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Call tophat, complain. Is it rubbing a little under normal driving or spirited driving, becuz if it's rubbing under normal driving... under spirited driving it may dent or could even crack the pan= no good.
-Dan
Joe
i dobut it would ever crack the pan, its a soft metal so it would dent first.
Vkoslak
Rubbing under normal driving. I need more parts installed before spirited drivng may commence. Stock turbo elbow didnt clear either.
Engine is right up against one of the AC lines across the firewall though, so I don't think it can go back any further even if I got different mounts.
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
unbolt the sway bar and make the holes for the sway bar mount bigger and rebolt the swaybar on. you should be good to go then. It dosnt sound like it is rubing too bad.
300Plus
Car: 1995 S14 w/ Rb25det Series II
s14 2510’s wrote:Engine is right up against one of the AC lines across the firewall though, so I don't think it can go back any further even if I got different mounts.
With my custom mounts we had the same problem so ...we yanked out the AC line. I plan on putting the AC back in since I live in florida, but when I do I'll run a line somewhere else.
And if the mounts dont do what they are suppose to do SEND EM' BACK.
Vkoslak
I was also thinking of putting some type of spacer between the front sway bar brackets and the car body. The pan front is angled and this would give me more clearence as well.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Vkoslak wrote:I am using the top-hat mounts, bought them by calling the number on their website. My rb20det's oil pan keeps rubbing the sway bar. So far it has only rubbed off a little paint. I thought everthing was supposed to clear when using the mounts? Is there any sway bar either aftermarket or from some other car that will work? I have a spare z32 sway bar, but it doesn't look like it will work.
I put a 1/2 spacers under the sway bar mounts worked good, i still have only about 1/2 inch between the oil pan and the sway bar but worked good.
Carl H
and yet another testimate to why one should use the r32 xmember when doing a rb20 swap.on my car the swaybar clears perfectly, and on my buddy neils car (bronze mfp) there is more than enough swaybar clearance.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Strange when I had the top hat mounts in my 13 it cleard the oil pan with room spare. Might be your car the fram might not be straight.
RB20DETodd
Carl H wrote:and yet another testimate to why one should use the r32 xmember when doing a rb20 swap.on my car the swaybar clears perfectly, and on my buddy neils car (bronze mfp) there is more than enough swaybar clearance.
I used the r32 crossmember and had to use spacers, i guess its another one of those things like the clearence between the elbow and the steering linkage some clear some dont, btw does anyone know if the s13 nismo power brace comes with the sway bar mount studs in it?
thanks
vg33t
Car: s13 rb20
Vkoslak wrote:I was also thinking of putting some type of spacer between the front sway bar brackets and the car body. The pan front is angled and this would give me more clearence as well.
That is exactly what I plan on doing.
