maikan wrote:Why some people disconnect these bar ?
Are they really necessary ?
the swaybar endlink controls body roll, it keep the truk riding comfortably when your going down the road and when your going over bumpy roads, so as the suspension flexes it trys to keep the body as leval as possible.
and why people disconnect these, mainly guys who do alot of wheelin (goin off road) will disconnect them, when your off road your purposely making the suspension flex and flex hard, doing this will eat up end links fast, thats why you can get quick disconnect end links that have a cotter pin golding them to the sway bar.
so are they necessary?.......i wouldn't say absolutely yes, by controling body roll they are kind of a safety aspect, but a very slim one, if you drive like a jerk on the highway and weave in and out of traffic very fast you might want them in, but i have a couple buddys with lifted jeeps and they dont keep them in. and yes there are bushings for the sway bar, 2 D bushings, if you get under the truk or get it on a lift you can see where the sway bar contacts the frame, i believe there are 4 of 5 bolts that hold a plate over the sway bar whoch holds the bushing and sway bar in place, note the bushings can only be purchased at the dealership.
