adrianfromthecastle »
https://forums.nicoclub.com/adrianfromthecastle-u30128.html
Wed May 09, 2007 10:11 pm
I'm not too sure if the LE's didn't come with it or not, but you should visually check to make sure. I know the base models w/ 4 lugs didn't... anyways, what you need for the rear is the bar (of course), endlinks, endlink bushings, "U" bracket and the "U" brackets bushings. Usually when you buy sway bars, they're all usually included.
Same goes with the front, but if your just upgrading the bar, you have to get a larger U bracket/ bushings and maybe a different endlink, depending on how your sway bar is designed. If your stock endlinks do fit the newer bar, you should get new endlink bushings anyways.
Installation is hella easy. I gaurantee when you look under your car, everything will come into place.
