sway bar endlinks damaged?
Saru of the West
Car: 91 240sx & 1997 Q45
due to alot of stress put on my car in the last 6 months the front right part of my car makes a nasty click and clank noise wehn i turn.This does not happen everytime butt alot of the time.
and after another night of serious action my left side dos not stock clicking even when i am just normal driving when ever i hit a bump or what not it make sa noise.
i ahve not jacked the car up o look and see if anything is broken butt i will butt has anyone had the same problems and solved them if so0o i need info.
slakker
Car: Cars and Comps
Could be or blown strut, busted spring, mashed t/c rod. Youll have to check..er out
alex7542
Car: Racing and high horsepower
it could be ur axle. check that out too. the axel could be going bad. and when its goign bad it usually makes a clicking noise when turning the when ur goign str8 it makes it to as it gets worst
Saru of the West
thanx guys well my tc rods are fine springs are cool and the strut might be blown, butt it also could be some suspension peice in the front taht might be the most probable answer i will get it checked out very soon.......... hey butt arent 240sx fr i dont think we have axles on the front?
NismoRb20S13
alex7542 wrote:it could be ur axle. check that out too. the axel could be going bad. and when its goign bad it usually makes a clicking noise when turning the when ur goign str8 it makes it to as it gets worst
its rwd and there are no axles on the front, i would say tie rod ends is your problem esp if they are old and you were getting on it hard.
the clicking on fwd's is the cv's getting ready to die
alex7542
YEa thats right im sorry my bad. i was thinking of a front wheel drive. my bad.
Adikt
its the spring perch mounts the popping sound ur hearing is the spring not being able to spin freely and popping into place
check pdm for replacement parts
