LeD ippen »
https://forums.nicoclub.com/led-ippen-u90522.html
Sat Jan 08, 2011 11:02 am
So i had my swap stock rebuild rb20der done since September. Now i want to run a front sway bar for autocross but here is the problem I have a nismo powerbrace and part of the bar is where the sway bar would be.
Setup
-R32 Crossmember
-Hockey mounts switch from e30 mount( Too Soft) works better then the Nismo mount i had for ka
-Nismo Power Brace
-Battle Version Tension
-Silkroad RA8 Coilovers
Has anyone run into this problem. I really want to keep the brace but also have the sway bar. I put a front strut bar and it helped the front a lot but still need that sway bar.
