Sway Bar and Endlink help!!
tamdo714
Car: 240sx
i am thinking about getting some sway bars soon. I'm probably going to get the Largus ones. Anything i should be worrying about wit these? i go mountain road driving alot. Current suspension:-stance coilovers-spl rear subframe spacers-spl ruca-cusco front and rear strut bar w/ triangle bar
i was also looking to get some new bushings when i get the largus sway bars. and i need to know the diameter of the bushings for the endlinks. here's the link if you dont know what i'm talking about http://www.energysuspensionpar...s.aspwhich one is it thanks!!!!
slavetothemuzic
Car: 1991 240SX Fastback
I know you didn't ask for other options, but I just wanted to say that you might consider a Suspension Techniques set. IIRC they come with the replacement bushings and they definitely have the end links included.
Not quite as thick as Largus, but much thicker than the stock toothpicks.
nismofly
Car: 89 Nissan 240SX Hatch
largus are too thick for anything but drifting
ST's arent adjustable
get progress, or get whiteline with SPL endlinks, shelf whiteline links can have binding problems
i thought largus wouldve come with new endlinks....most high end sways do
just get the ones i mentioned with new endlinks instead of new bushings
tamdo714
Car: 240sx
thanks for the insight. but with the spl endlinks. looks like they only sell the rear ones??
nismofly
i havent checked in a while, just get progress and you wont need to worry about it
sleepyRPS13
Car: to sleep
largus front is adjustable. there's 3 holes to put the endlinks.
adjustable solid endlinks are available separately, front only just like spl.
get largus!
