Swaps Info
Defau1t
Hello,
I was wondering if a sr20det clip swap would override the need of a manual transmission swap.
It sounds kinda stupid to me as i sit here and type this but i just dont want any confusion later.
and if someone would be so kind to inform me of what exactly is needed to be swapped within
the interior of the car during a transmission swap it would be much appreciated
:slap:
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
What exactly are you going to use out of the clip? If you are doing dash. You will need to do firewall and everything! If what you are asking is will you have all the parts needed to convert It to stick the answer is yes. If you are keaping it left hand drive the only thing I'm not sure about is if the clutch pedal assembly will bolt up on the driver side.(American).
