My question is, would it be possible to use the Automatic for a parts car and just buy a used Manual ECU? If so, would an 88-89 ECU work? (JWT only upgrades 88-89 ECUs)
Following this link: http://www.redz31.net/pages/turbo.html
This is the list of parts needed when performing a turbo swap:
T3 Turbocharger and exhaust elbow from 84-87 300ZX Turbo
Drivers side exhaust manifold
Downpipe
Front crossmember (both the crossmember and engine mount bracket must be swapped for turbocharger fitment)
Drivers side engine mount bracket (bolts to block)
All intake piping (from Airflow meter to Throttle body)
Alternator mount, tensioner (and longer belt for application because the alternator mounts on pass. side instead of drivers side)
Oil pan
Turbo oil lines (and water lines if applicable)
Fuel injectors (260cc/min instead of 180cc/min)
Correct ECU (Interchange info here)
All applicable gaskets
Is there anything else I might need if not listed here? (Just in case)
I just want to make sure I'm buying the right turbo parts car.
Any suggestions are welcome!
Thanks
