Swapping transmission on 99 Frontier, from an Xterra or pathfinder, of similar year?
JustJammedUo
Car: 2012 Nissan Rogue
1999 Nissan Frontier
Hi we have a 1999 Nissan front tier, with 298,000 miles on it. It drives very well the cabin is very clean, but it has one problem. You cannot go over 50 miles an hour, otherwise the RPMs go up, and it sounds like it’s going to blow the motor. We’ve had it checked out by four different mechanics, who’v all said that it runs fine.
None of them have highway tested it.
I have heard that the frontier transmission has been problematic, and I would like to swap a Xterra transmission, into this vehicle if possible.
Nissan frontier 99 2WD/4Cyl
Thanks!
JustJammedUp
PS: I was unable to use the search feature, or I would’ve looked to see if this question has been asked about this particular vehicles transmission issues.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
You'll need another one from another 4 banger 2wd truck, otherwise it should work just fine. 98-04 are the years to look for. Not a lot of 4 banger Xterras out there, but there are a few.
JustJammedUo
Did you mean any 4 banger 2WD truck, or any nissan ?
Desert Rat
2017 Frontier 4.0
2008 Boulevard C90T
4 banger 2wd truck.
