Swapping Tomorrow
T_love
My RB25 will be going in tomorrow.
Is there any last minute words of advice anybody would like to offer?? Anything that comes to your mind will be very helpful
Thanks
xjon
Car: 99XJ, 93 240coupe
Good luck and have a lot of perseverance. Well, at least I needed it.
BoostFab
Car: S13cp, S13fb, S14z
is it the clip?
T_love
no, motorset
gprodigy85
goood luck... yeah perserverance, youll need that. lol
T_love
thanks
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
Put it in from the bottom with the trans attached (if you hadn't planned on it already)... saves a lot of time and frustration. Pick up a can of PB Blaster and start soaking some of the bolts/nuts you will be taking out... saves some more time and frustration... and trips to the hardware store.
Did you get a mounting kit for it? If so from who? Just trying to get an idea of what you are dealing with...
T_love
no mounting kit. i'm using the r33 crossmember
goofynick6
Car: 1995 S14.5 RB20DET
Start taking anti-depressants now..
Wulfgang
Take your time and do it right the first time.
Btw, if you are using the sidemount... be aware that it will not fit correctly (under the OEM fender plastic) no matter how much cutting of the bumper and fender you do UNLESS you use custom piping also. That semi-upward bend on the cold pipe just won't fit. Get rid of it! I have mine bolted in, but now the plastic won't fit. And that was after lots of cutting.
Wait. Better idea. Just get an FMIC.
T_love
Wulfgang wrote:Take your time and do it right the first time.
is there any way of ghetto rigging(sp) it to fit. I had no plans for a front mount any time soon. Good thing i asked before diving in
goofynick6 wrote:Start taking anti-depressants now..
bottle is already half empty or half full depending on how you look at it:)
By the way swap won't be going on until next weekend coz i was a little late on renting the cherry picker and i can't getting till next week
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
I got mine to fit in my S13 with stock piping, and I would agree that it was a giant pain, and you should seriously just consider a FMIC now.
To make it fit in the s13, I had to take the mounting bracket off, and flip it upside down, and then cut, drill, bend, grind, hammer, you get the idea. My FMIC is on it's way.
T_love
I'm guessing running with no intercooler for a couple of weeks is a major no-no, right? funds are running low so i don't want to get fmic and other things i was planning on doing much later, then end up with no money to finish the swap itself. i still need a driveshaft and there's always those little unforeseen penny-pinchers.
Is the fmic piping completely custom or does the R33 piping come close enough to fitting perfectly?
gprodigy85
fmic piping is all custom, you can make it use some of the stock piping if you wanted im sure ...
look on ebay for a spearco core, they run about 250-300$ then you have to figure out how you want to mount it and get brackets welded to it, then make the custom piping... but its still cheaper than one of those hybrid kits on ebay.
NISMO_RB25
You can use PVC pipe to make the sidemount fit. frosted did that on his swap. I probably wouldn't run that permanently, but it is a cheap and easy temp solution.
That Monster Hybrid R33 kit looks awsome, and the piping should all fit. I have one on order right now.
T_love
I think i'll go the PVC route first just to get back on the road then when things settle down i'll get the FMIC
By the way does it matter than the inlet on my intake is 3" and the Q45 MAF has a diameter bigger than that? Will that affect the reading or not. I just bought one of those Autozone cone filters since i couldn't find a Q45 Maf adapter anywhere
Wulfgang
Hey, I didn't say that it wouldn't fit. I just said it won't fit correctly. I had to do lots of cutting just to get it to fit (incorrectly). And I was able to get the plastic on, but it's certainly not how I want it long-term. I plan to make a new cold pipe that runs a bit lower, possibly out of PVC for the time being, then with mild steel later on.
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
mckinney has a front mount piping kit ! they also sell a core. im not sure if it comes with any end tanks tho.
