gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Fri Feb 22, 2008 8:44 am
the load value in the PFC is calculated using the TPS voltage, so it might affect the way your Y-axis travels if voltage isn't right. you'd probably also want it 4.5V WOT, .5 V closed. most likely its just a linear relationship as well. i'd say try to see what kind of range you have right now by looking at the commander (wot and closed), then wire up the LR one and compare.
theres also a throttle switch in the 26 TPS. not sure if 25 TPS has one. basically it is continuous when the voltage is below a certain point (on mine it's when it's below like .43v, so i set my throttle to be closed at around .43v so that switch gets continuity). might want to check that out as well. however, i've noticed that it doesn't affect the idle when the switch is on or off.
