Aeroz »
https://forums.nicoclub.com/aeroz-u120182.html
Mon Mar 23, 2009 10:41 am
Wondering if this is possible? I got a KA24e from a Nissan Pickup, and I have a blown ka24e in my '89 240.
The main difference is the intake manifold which I switched over. Both are from a manual, so the flywheels are the same. My 5sp transmission from my '89 bolts right up, except for 2 bolts.
The main issue I am having is the oil pan, with the sump/bulge on the front on my '89 motor, and the sump on the back with the truck ka24e. So when I'm dropping the new motor in, it sits on the axle, higher than it should be, not allowing me to bolt in both motor mounts.
I can't swap the '89 oil pan with the new motor as it doesn't fit.
Any ideas?
Is there anything else I need/watch out for?
Thanks.
