Swapping s14 trans into s13, any difference??
Shaefer Thomas
Car: 1992 240sx
Hey guys,Just purchased a trans out of a 95 s14 to put in my s13 due to syncros and whatever the hell else being bad in my s13 trans. Just wondering before I go tearing it all apart, is there any difference or is it a direct fit? What should I be replacing while I have the trans out? Sensors a problem? Any help would be appreciated. Thanks guys!
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Direct fit...the S14 trans will have one extra sensor on the bellhousing, ignore it.
Use your S13 speed sensor and other electronics and it will will be a remove-and-replace deal. Easy.
- Brian
Shaefer Thomas
Car: 1992 240sx
Awesome man, much appreciated!! Any seals or anything that I should replace while I have everything out?
