Swapping S14 KA into S13 Chassis
Young_240_Guht
Car: "90 Nissan 240SX DOHC
I'm in a hurry need to get to work, and need to know what to do to electrical side of the swap? I'm about to buy a newer KA, and wondering if i need the harness as well?
Any info on this swap is helpfulTIA
xyzalvarez
i know that the 95 harness its different compared to the 94 and early year harness...some sensor are mixed or dizzy wiring....something like that..
probably you can get a convertion ECU harness in order to keep it clean.
im fact im trying to do the same...i have a 95 engine and looking to use a 94 ECU and harness...
on a non 240 chassis..!!
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Swap in the intake manifold from the s13 onto the newer motor and drop it back in the car. Use the electronics from your car as is with the newer motor.
Young_240_Guht
Are you Effin with me? O2 sensors are teh same? injectors, coolant sensors,
jc9up
Car: 93 240sx super hicas
just did the same to mine..put a 95 ka into a 93 chasis...only thing i had to change out was the intake manifold....that easy!
JeromeS13
Car: 2008 Subaru Impreza STI
And distributor. This topic has been beaten to death. Search around and I'm sure you'll find numerous posts and maybe even a DIY.
-Jerome
jc9up
^^sorry forgot about the dizzy..but yep that easy!
Young_240_Guht
jc9up wrote:^^sorry forgot about the dizzy..but yep that easy!
How easy would it be to mess up the disk inside the dizzy?
