jspout »
https://forums.nicoclub.com/jspout-u146193.html
Wed Dec 09, 2009 10:35 pm
Hi, I already swapped out the rear struts and spring assemblies. That was pretty easy. The fronts look a little more involved. I'm just swapping the whole spring, strut and hub assembly like the rears. I won't need to compress the springs for that will I? It looks like I will have to take off the bolt from the tie rod, the 2 lower arm bolts and the brake line mounts. I will keep the brake stuff where it is from the old one. That sound right? Any advise before I dive into it? Thanks
