johngriff »
https://forums.nicoclub.com/johngriff-u30588.html
Sat Sep 22, 2007 7:08 pm
Drill a 1/8t inch hole in the body of the thermostat. Install with the hole facing Up. This will help the system balance pressure and bleed air.
Amount of water is so temperamental. Catch all the coolant you loose. Match the amount you loose in your chosen ratio of 30/70+12oz divided by 3.5gallons.
After doing this, warm the car completely up, really really hot. Turn on the heater. Jack up the front nose of the car. Unthread the bleed screw a few turns (located on the hot/top hose fitting to the cyl head) until you see water and air come out. Do not completely unthread. Watch this bleeding process until only coolant is coming out.
