swapping my intake!!!
Nissan 350z / Nissan 370z general community discussion forum
gmoney350Z
Car: 06 nissan 350Z
i already have an AEM cold air intake on my 06 350Z, and ive heard with a short ram intake you get alittle more hp for it cuz of the short tubing!
so im thinking of swapping my AEM cold air intake for a fujita short ram intake...........
you guys think its a good swap???
thanks
xjmxstac
Car: 2003 nissan 350z track edition
CAI vs. SR have their pros and cons. SR might have less restriction but it draws hotter air because the cone is mounted inside the engine bay. CAI might have more restriction but it draws cooler air away from the engine bay.
One thing I'd consider, seeing that you're from cali too, would be SMOG. AEM has an approved CARB # or EO #, while Fujitsu may not have one. Tampering with emission systems in the state of California can prove to be a considerable fine and/or penalties.
gmoney350Z
Car: 06 nissan 350Z
but from a hp gain.......which will be better stay with my CAI or get the SR?
xjmxstac
xjmxstac wrote:CAI vs. SR have their pros and cons. SR might have less restriction but it draws hotter air because the cone is mounted inside the engine bay. CAI might have more restriction but it draws cooler air away from the engine bay.
This being said, you'd have to do research on the different CAI and SR brands. Different manufacturer's have different designs, some more efficient than others. Basically, you'd want to look for an intake that gets the coldest possible air with the least restriction. It's hard to say that CAI is better than SR and vice versa because they have their pros and cons.
Living in San Diegol, I decided to go with CAI. It's warm for most of the year, so heat soak is likely if i got a SR. We get 10-12 inches of rain annually--this means that I don't have to worry about sucking up water through my cone which is located near the front wheel well. For the months that it pours and floods, I switch to stock.
NFSP 350
Car: 04 Nissan 350Z Red Enthusiust
Just so I can sound like a broken record, there are pros and cons. Im setting up my intake system right now. I ordered the Injen MR intake, converts SR or CAI. I will be running SR. Im going ti fab me a small shield between the cone and block. To ensure fresh cold air, I have a TiTek carbon fiber intake duct to mount in bumper.
If you think you like my setup, I accidentally put 2 TiTek ducts in my cart. Im only using one so I might have the second to sell. Some locals are trying to use on M3 or miata. Dought it will work.
gmoney350Z
Car: 06 nissan 350Z
yeah i get ya!!!
i think imma just stay with my CAI and get a nismo y pipe
now i just need to find one
does anyone know where i can get a brand new one????
ldstang50
I have the y pipe of my 07 nismo if you want itnot sure if thats what you're looking for
gmoney350Z
Car: 06 nissan 350Z
do you think it will fit???
cuz i have a 06 350Z with a nismo exhaust, and i think the 07 nismo exhaust is lil different or maybe im wrong.
bmike818
Car: 2007 Z
I have an 07 with a 06 Nismo exhaust. I can sell you my 06 y-ppe, so I can get the 07 y-pipe from Stangsters.
they should be thesame.....(i think)
ldstang50
I know it will fit, but I don't know if you'll see any gains. I know the G guys like the 07+ y pipes as they saw gains with them
gmoney350Z
Car: 06 nissan 350Z
how much you tryin to let it go for?
gmoney350Z
Car: 06 nissan 350Z
im just tryin to replace my stock y-pipe with the nismo one cuz i have the nismo exhaust with 3' inch mid pipe.
i dont think i would gain anything but you never know!
rmezz13
Car: Had 2004.5 Nissan 350z
Have 96 f250 and mommas 07 Murano
FWIW i have the Injen CAI but had iut set up as shart ram for about a month and it was a noticable difference from the stock pipe + popcharger, then i went ahead and set it up as the CAI and i could notice even more of a differnce with the CAI over the shart ram... Not just sound, felt more responsive and "powerful" i guess...
gmoney350Z
Car: 06 nissan 350Z
wow! that really makes me wanna stay with my CAI
ztunelover
Car: 1995 Nissan 240sx
get top secret itb kit plus stand alone, it will give you big gains.
im sorry guys but i had to make my one stupid comment of the day
mind you if you do have the money its a good way to make big n/a power.
ldstang50
gmoney350Z wrote:how much you tryin to let it go for?
I'd be looking to get rid of the full exhaust (cat back)
gmoney350Z
Car: 06 nissan 350Z
yeah but im only looking for the nismo y-pipe cause i already have the nismo exhaust with 3' inch mid pipe!
but ill understand if you dont wanna sell it
Return to “350z / 370z Discussion”
