sijia10358 wrote:the cross memeber is from my 5speed Sr20 trans
on the diagram the 11320E, the hole on the crossmember is about half an inch off...
Something is not right. You are talking about these two holes, right? That's where bolts on the transmission mount go. I also have a Nismo transmission mount with KA manual cross member. Nismo transmission mount should work for both KA/SR. Please answer these.
- Part # on transmission mount- Is your cross member from sr20det or sr20(N/A)?- What's the distance between two bolts on the transmission mount?- What's the distance between two holes on the cross member?
I'll check my car tonight.
