RPS13-NY »
https://forums.nicoclub.com/rps13-ny-u190619.html
Sun Jan 15, 2012 4:57 pm
Ive been on the road to my turbo swap for a while now checking parts off the list weekly so far ive got: Z32 MAF, Nismo Motor & transmission Mounts, Tomei Expreme Manifold, i still need to get a turbo back exhaust, Injectors, FPR, Nistune, & NGK NTK/AFX Wideband.
What do you recomend for 550cc Injectors? HKS are preeetty expensive & im not sure if i should chance going with some used ebay injectors.
what exactly do i need for a Fuel pressure regulator? ive been told the nismo type B is one of the better FPR's because you can choose to not mount it directly on the fuel rail, but then i just need a bracket for it?
I just took my ECU out so its ready to be sent to Nistune, when i get it back can i just plug it back in and go take my car to get tuned or will it need a tune to drive?
Thanks.
