Swapping Differentials
Ethien161
how difficult would it be to swap out an open differential with a Differential with a Kaaz already in it before and after events? because if heard that the Kaaz' break after 2-3 years i was thinking i could use it for longer by trading it out like i just said
Justin35ll
Car: s13 coupe sr20det
it's too much work to do that. And 2 -3 years is a pretty long time anyway.
All you're doing is taking out 4 bolts for the diff cover, 12 axle bolts, and 4 driveshaft bolts, but taking that thing out and putting it back in is horrible just because it's so heavy and you gotta manuevor it around
and after driving with the lsd why would you wanna go back to an open?
Ethien161
no i mean like ill have one differential with an lsd in it and another differential thats open and ill swap out the two cases not taking out the lsd from the cases and swapping em
ChampaignSilviaS14
Car: S14
Yeah.
Not worth it at all unless you have a lift and air tools.
Actually even then its not worth it.
Ethien161
k thank you guys
assassin7420
Car: 1996 Nissan Silvia
1995 Nissan 240sx (daily)
Wow.... Someones a baby.
It takes me 30/45 minutes to swap pumpkins. No lift, No air tools. Why you would ever want an open diff though.....
S14toRPS13
Swapping out pumpkins is simple. Jack up your car loosen up the driveshaft, axles, and rear mounting bolts then lower down and do the same to reinstall the other pumpkin. No more than 30 minutes once you get used to it, but I'm sure after a while, you'll just rather drive around with the lsd installed.
240tunerguy
Car: s13
its an easy procedure. but why go with open when you can have lsd? i would stick with the lsd
slow40
Car: S13
is that true about them breaking in two to three years? Which type is more durable?
White Comet
Car: fc, s13 and mazda6, Sierra
its an easy procedure sure, but i would not have the motivation to do the extra work to end up with an open diff
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
yea i dropped it a total of 3 times over winter when i was doing some serious work
needless to say
its not comming out anytime soon
SR24DET
Car: RMS13
For those of you who say takeing it out is simple and can be done in 30 min, have you really ever done it? I agree its not complicated, but I wouldnt say easy. removeing the bolts are easy, But manuvering that crazy heavy SOB around under the car with little room isn't fun. You need to d!ck around to get the axels to pop out. Then you need to d!ck around droping it while getting around your exhaust, sway bar, and subframe. It is a pain in the a**. I have pulled my diff over 4 times, and I have also done it to 4 friends, so I have done it alot. It is always a pain in the a**, and it takes some time.
240tunerguy
Car: s13
truthfully its not that hard to do with the right tools, and a nice pry bar helps out alot too with the axles. and im talking on the ground, hand tools, no air tools or lifts. i can say it honestly takes about 45 minute to an hour and im not saying i would swap my open for an lsd everytime i go to the track. thats just a waste of time.
White Comet
SR24DET wrote:For those of you who say takeing it out is simple and can be done in 30 min, have you really ever done it? I agree its not complicated, but I wouldnt say easy. removeing the bolts are easy, But manuvering that crazy heavy SOB around under the car with little room isn't fun. You need to d!ck around to get the axels to pop out. Then you need to d!ck around droping it while getting around your exhaust, sway bar, and subframe. It is a pain in the a**. I have pulled my diff over 4 times, and I have also done it to 4 friends, so I have done it alot. It is always a pain in the a**, and it takes some time.
i'm pretty sure i can do it in less then 30 minutes, but thats because i use an impact wrench and the pit
AZ89two4Tsx
I was thinking about doing this, except I have a welded. I'm lazzy so I don't.
Hope that helps.
