Mighty GA16? Are you being sarcastic, or does the engine has it good sides?themadscientist wrote:Ah, the mighty GA16...
Haha I know! It's a nice car, even no rust, and it's still the first paintjob!:)float_6969 wrote:It's like a FWD S12 with fixed headlights! It's do-able, but you've got quite a road ahead of you, and I'm of little to no help.
So you've done about exactly the same, what I want to do? I will look into your posts, I'm curious!:)Sentrastic wrote:It's alot of bullsh*t dude....I'm in the process of completing my B12 CA18DET Sentra, with LOTS of help from Dee, he's supplied me all of the parts pretty much. Some of the parts were really hard to find, finding any 1.8L Pulsar is a pain. Basically if you can get your hands on a 1.8L Pulsar with a CA18DE, half your problems are solved. And I'm using an SDS Standalone ECU to complete this project. So as you know, this is not cheap whatsoever.
After over a year and a half I'm in completion of getting my custom axles made.
Search my first posting that I made here, Dee replied with alot of helpful information when I stepped upon this as well. All of the information will fit your build as well.
But your really lucky to get that Sunny, I'm dying to get a bunch of exterior parts from that car.
Haha so not even close right? Are you suggesting to take an N13 and use parts of it?Liquid_Neon wrote:I am horrified that you would sacrifice an N13 to swap your ca into a B12!! horrified i SAY! /sarcasm
unless the car is already wrecked I can think of a few ppl that would need/want those cars to merge with out exsisting N13s(or jsut to have another one!!)
Ah right! Maybe I will go and look for an N13 then, I think they are for sale here for cheap prices, or otherwise a partscar:)Liquid_Neon wrote:Well much as i hate to see a rare bird like my beloved N13 get used as parts... it is prolly the easiest way to get everything you would need to mount a ca18det in a fwd nissan. seeing as over here, the SE model came with a 125hp ca18de.
So if u were to use one, you would have nearly everything u need for a det in your B12. would be time consuming i'm sure, plenty to weld and make fit.
Also parts are gettign harder to find for stock pulsars let alone modified stuff
Nice, i'm interested how the project of you will continue!Sentrastic wrote:Yes sir! Not exactly "done" but I'm in completion.Very excited, I'll post pics and videos soon as I get this thing running and bring to life my old toic I posted here a year ago.
It is very exciting but patience is a must when sourcing parts. I'm actually working on my wiring right now (getting all the gauges and wiring nice and clean), as far as the custom axles I did it because I'm using a Bluebird transmission. I'm sure you can use the Pulsar transmission and axles as well as I would think its the same fitting as the sentras. I didn't cross that road so Dee would obviously know MUCH more about this.
It really depends at the end how much your willing to put in to your project as opposed to horsepower, LSD, ecu, and so on.
Be ready cause your car will be TORN apart, in the mean time you can also Paint or make your interior nicer as well.Basically, you will need to find an 88 or 89 Pulsar SE and rape it . Yes, you must take all the pedals, shifter and linkage, 5spd transmission and bracket, bracket that the transmission mount bolts to, clutch master and slave, passenger side bracket that connect the engine to the mount, bracket that's bolted to the block and has the a/c compressor and alternator attached to it, bracket that the P/S pump attaches, radiator and hoses if they are good and most importantly, don't forget to keep all bolts you removed assigned to the areas you removed them from. Hope this jump starts your project.
Nice! I'm curious!s13drifter88 wrote:I have a buddy that is a B chassis guru. Ill see if I can get him on here to help you some. Dee is also very familiar with the chassis as well so he would be of great help as well
Sentrastic wrote:Take a look at my first posting.
I'm sure the front end of your Chassis is identical with the Sentra.
Here is what Dee first told me:
