The
craigztoyz wrote:2nd thing.
I sent you a full harness with the pigtail set you wanted, right out of a Q, worked great on car before pull, you said you never got it, so I made another, then shipped it with ups, they dropped it off per their info to me when I checked. You then sent me one, because I was already loosing money on the deal after 2 harness, then you said to send it through the postoffice with teir tracker, so I did, checked back a week later all was good, you said thanx, never heard from you again, till a year later. Uh What? If you;d like to discuss this, Hours are M-f 9-5 CST, if you need the number again my email is
[email protected]
The reason you never heard from me again is that you are so full of BS stories that I can't do business with you. I simply gave up and used my time and energy finding another way to make this work.
I repeatedly asked for tracking numbers for the first two "lost " harnesses, instead of providing those numbers, you absolutely ignored my request, never even addressed the tracking numbers for the lost packages. To this day you have never sent me any tracking numbers for the lost harnesses.
The harness I ended up sending to you had the MAF plug clipped off, I took pics of, and paid careful attention to the place, angle and method the plug was clipped.
When you returned the harness you stated that you had run the harness on a test vehicle over the weekend.
I also asked you about the MAF plug. When the harness came back, the MAF plug was clipped off exactly the same as when I sent it to you. You said that you had to add a MAF plug for testing, then cut it off again before returning the harness to me.
Comparing before and after left little doubt that you never touched the MAF plug.
Which leads to the next question of how did you test the harness without a MAF plug? I might be wrong, maybe you have a way to wire in a MAF plug without touching the harness, but even the grease over the end of the cut wires was the same.
The question still remains, if you were an expert on the conversion, why were you on the this forum asking how to make a conversion? As I pointed out, your question came conveniently close to the time I paid you to make a conversion harness for me?
Appears that you started the BS when you charged me for work you said you could do. Then you have the lack of good sense to ask a question, on a forum where I am active, about how to make a conversion harness?
Finally, its not slander if it is true. Provide me the tracking numbers for the first two harnesses and explain the MAF plug, or else back off.
