pmkls2 »
https://forums.nicoclub.com/pmkls2-u8760.html
Wed Mar 18, 2009 6:45 am
In order to swap the internals into a non-vlsd housing you have to have the proper stub shafts which you have, but the axle flanges are the 5 bolt pattern instead of the 6 bolt pattern. There are 2 ways to solve this problem. First you can aquire a set of 6 bolt stub shafts, but you will have a hard time finding them anywhere other than the dealer and they cost about $300-400. the alternative would be to find a pre-'96 infiniti j30 at the junkyard and use the axles out of it. The flanges are 5 bolt just like the 300zx and the length is the same as the stock 240. Also, the splines on the hub end are the same and will fit. I went that route on my vlsd swap and I can verify it does work. Also, the 5 bolt axles themselves are stronger and can take 450+ hp so if you ever go turbo you have plenty of assurance
